Dear all
I own a Beolab 2000 type 1642 sn 14785202, connected through Masterlink to Beoport (set as AudioMaster) and Beovision 7.32
While I'm able to select and listen N.RADIO and N.MUSIC by using the remote Beo4 on Beolab2000, I'm not able to do that using the buttons on Beolab 2000.
If last active source was N.Radio and no other diffuser in my home is listening N.RADIO, then swtching Beolab2000 off and on again, N.MUSIC is always activated.
If any other diffuser was listening N.RADIO together with Beolab2000, then swtching Beolab2000 off and on again, N.RADIO is activated.
Button RADIO on Beolab2000 seems to have no effect on trying to select N.RADIO source.
Is there any SW update can be applied to solve this issue ? It would be useful not to have to use Beo4 on a device that born with buttons.
Many thanks and best regards to eveybody
pleonipi
