Hi All,
I've got a question about Beolab speakers and would like to know your opinions.
I'm in my 40's and the music i mostly listen to is dance music with heavy bass, groups like Faithless, New Order, famous DJ's like DJ Tiesto, I mainly use a Technic's 1210 mk2 turntable, CD's from the 9300 and mp3's from my phone.
So i have a Beocenter 9300 and a couple of years ago i brought a pair of Beolab 4000, they sound good, until you crank up the sound level......so i purchased a Beolab 2, great for the low bass.........after that i wanted the mid to high range better so i purchased a 7.1 sound bar, that did the trick.........After that i wanted the music louder so i purchased another set of Beolab 4000 which increased the sound level.
The max sound level from the Beolab 4000 is 97db, I believe when you double the speakers you increase the db levels by 3 db, so adding the 7.1 and 2nd pair of 4000's should now get me 103 max db?
The room i have all of this stuff in is an annex building away from any neighbours so i'm not annoying anyone, the building is a brick building with plasterboard walls and real oak flooring.
So recently i've been thinking about selling all of the speakers and getting a pair of Beolab 9's will it sound any better/louder??
Considering most of the music played is bass heavy will i still need the Beolab 2 ???
What do you think?
