BeoLab Penta1 Stupid Question from Newbie
Hi--I just got a pair of BeoLab Penta 1's complete with BeoCenter9000
Hooked up it reads on the speakers the CD output but no sound.
Other problem is I would like to use them as front speakers in HT system
Hooked up line out from Denon3802 receiver and plugged in the speakers
again NO Sound.
---Third try decided to bypass the built in Amps and ran speaker wire
from the Internal banana plugs to HK2.1 signature amp---
result No Sound.
What am I doing Wrong are these worth repairing????
Can I when repaired just use the Penta's in a Home Theatre setup
as mono block amps and just run a signal from the receiver????
Is this possible????----and will it sound good as the fronts in a Home
theatre system?????
----Electronics Status-----beginner.
Pls help if you have the patience and time to answer what I realize
probably aren't to bright questions.
thanks
Under the amp section there should be a switch which you can switch dependant on the source (TV or audio).  Try that.  Do the amp power lights change from red/orange to green when they are switched on?
They are amazing speakers, I cant understand why you have no sound at all do they lights on the amps change to green??  It sounds like its something in the speaker unit?? Cheers Nick
BeoLab Penta Mk. 1.          3 polet DIN stik for lyd & display.
BeoLab Penta 1
link
Unfortunately, I write only Danish / Peter Pan
Thanks for all your help.
Right now I have them passively amped.
I ran speaker wires from the upper internal
banana plugs to my HK2.1 signature and I'm happy to report although no display
they sound great.
Does this mean I can also get the displays
working on a Denon Receiver?
Thanks for all the info.
Even if they end up staying passively amped they are keepers.
I traded a DAC for them so I'm happy.
lefty11
No, the displays will only work with a suitable B&O Beomaster or Beocenter amplifier.
I also got a beocenter9000 and a
remote1000 with the package---the displays do work using that but as I want them for fronts in my HT/Stereo guess I will
live without the displays.
Question
The beocenter9000 cassette tape door won't open is there a manual override to
get it open???
The CD load door works fine and also the
amp is fine as it plays CDs flawlessly.
Tape door isn't a big issue unless easy fix
as I don't need it to play tapes anyway.
I'm still stoked my trade was
Beresford 7520DAC in return I got
BeoLab Penta Mrk1's
BeoCenter9000
BeoRemote1000
After hearing the Penta's I would make this
deal all day long----they are just gorgeous
no dings and one little pull in the grill cover
you can't find unless you know where it is.
My first experience with B&O and I guess
I'm on my way to being converted.
Lefty11
Hi Lefty11
Its easy to like the Penta´s :D
If you dont want to use a Bang-amp (first choice with 4-pin special DIN as seen on pic above) then I would use Line INPUT from your pre-amp/line out connection on your amp. There will be no info on displays tho but personally I think that is the best way.
The Tape-door shouldnt be that hard to fix, should prob be hard and old "lubrication". Try search here on the forum coz I have seen some posts on similar problems on BC9000/9500/9300.
Cheers
Jesper
Sweden
Out of interest what did you think of B&O before you did this deal??
Before I did the deal B&O wasn't even on
my radar!!!!! Was just kinda looking for
some good front speakers for music and
home theatre about 50/50.
I can tell you even passively amped I'm
very happy with them in both venue's
We watched Inception tonight and the
Penta's did it proud.
Also the WAF (wife approval factor) is very
high on these even though they're over
twenty years old. I never imagined I would
get away with big speakers in the front but
these seem to have a timeless style in
my opinion and obviously in the little ladies
as well!!!!!
Life is good!!!!
Lefty11
