Hi--I just got a pair of BeoLab Penta 1's complete with BeoCenter9000
Hooked up it reads on the speakers the CD output but no sound.
Other problem is I would like to use them as front speakers in HT system
Hooked up line out from Denon3802 receiver and plugged in the speakers
again NO Sound.
---Third try decided to bypass the built in Amps and ran speaker wire
from the Internal banana plugs to HK2.1 signature amp---
result No Sound.
What am I doing Wrong are these worth repairing????
Can I when repaired just use the Penta's in a Home Theatre setup
as mono block amps and just run a signal from the receiver????
Is this possible????----and will it sound good as the fronts in a Home
theatre system?????
----Electronics Status-----beginner.
Pls help if you have the patience and time to answer what I realize
probably aren't to bright questions.
thanks
