Beolab Penta MK3 6631 Service Manual / AMP & Crossover schematics
Hello.
I am looking for service manual for the Penta 3 6631. I've found one online, but it's only 8 pages and seems to only contain info on the "mains transformer" and diagram for the led display.
Could anyone be so kind to provide me with or point me in the direction of schematics for the Penta 3 6631 amp and crossover.
Thanks in advance.
Hi
I also only have the 8 page service manual for 6631(MK3). So I can't help with supplying you there.
I checked the service manuals for MK1 and MK2. From what I can tell the Crossover Network for those two look exactly the same.
I don't know, but perhaps there is no difference from MK1-2 to MK3. I hope someone can verify that.
I also managed to download the 8 page service manual, but I found nothing else online. Although I didn't try very hard to be honest. There's a paid membership in this forum that will give you access to all sorts of manuals and documents for B&O products. Maybe you should check that.
Also let's see if Keith the moderator can confirm if there's more info available on the Penta with the upgradable membership.
Good luck!
Thanks for the replies guys. I have access to the manuals here on Beoworld, but it's the same manual with only 8 pages.
It would be very nice having someone confirm if the crossovers are the same regardless of which version they are, however I don't think that's the case as the website where I bought the new capacitor kit for my crossovers states the following: "Because this kit fits several versions of crossovers, it may contain a few components that will not be used in your version."
Thanks again for your inputs.
There are at least five different crossover versions.
Thank you for your reply. So even if I was to get the «complete» service manual for mk3 (if there even is such a thing), it wouldn’t be of much help as it may not have the schematics for my exact crossover?
I tried reaching out directly to B&O, but they couldn’t accommodate my request.
What is it, you want to know?
