Sorry for the long winded description skip down to the CAPATILZED headings if you want to get to the point.
I have just picked up a pair of Beolab Pentas locally for a GREAT price. Of course there are caveats to that price. They were shipped to the previous owner from their parents (they had fond memories of the Pentas from their younger years). They were crated, but one of them arrived slightly beaten up (small dents on some panels). The owner said that when they connected them to their BC9000 the 'batterd' one, '...smoked a little and stopped working.' After that they were stored for years and only brought back out recently.
They had one running its amp and the other was rigged with a lead running through the amp housing to the direct speaker connections (Beovox style); strange set up in my opinion. Leaning in to them at low volume I could hear the 13cm speaker just below the mid ranges sounded distorted. Still for the price I was game for a gamble and they wanted them to go to some one that would use them.
My plan - Get the speakers up to scratch, then consider new caps, then maybe tackle the amp.
SPEAKERS
13cm - I took off the front panels (those release details don't work very well!) and removed the broken amp from the slightly battered Penta. I then hooked it up, without the amp, to my BM2000 (only 25watts, but it was on my work bench already) and played various genres at low volume (it was late at night). The speaker just below the mid ranges was distorting frequently and the one just above them was slightly distorted as well. I tried switching the units around to see if the problem was electrical, but the distortion followed the speakers. Gently/slightly pushing on their cones resulted in grinding; more immediate than pushing on the 'good' speakers. Certain points around the cone seamed to be more probe to grinding than others. There was no visible damage to the cones, surrounds and spiders. Could the bad shipping have misaligned them? Are they blown?
Today I decided to hook them up to my BC9000 to see how bad they sounded at higher volume. Turning the volume up seamed to eliminate (or maybe mask) the problem. Obviously I can not get in close to really listen to the individual speakers at high volume ;) Lowering the volume I felt that each 13cm speaker sounded different, or at least different levels of vibration (am I just paranoid?) How can I conclude if I need to replace the 13cm speakers, or not?
8cm - Will re-foam these, once the 13cm speakers are sorted out. I have done my CX100s and am planning on following Martin's advice to shim on this project as well (to avoid any disasters where possible).
Would the general advice to replace the caps solve any of these symptoms? I am game to replace eventually, but would ideally like to sort out the speakers out first.
AMP
I do not have a clue where to start. I checked out the fuses and they do not look burnt out. I do not imagine they would create too much smoke anyway. Due to the mention of smoke I have not plugged the amp in my self, yet (of course I do not know if it actually smoked, or not). Advice welcomed.
If I want to use them as Beovox, until I sort out the amp, I am guessing I need some shorter thread pieces (Beolab has long ones that run from the bottom of the speaker, through the amp, to the base)? If so any idea where I can find some?
I did run the good amp on the other speaker. Only used regular speaker cable (which cable do I need to get the best out of these and the display working, Beolink?), but it sounded pretty dam good. I can not wait to get these in good working order and try them out for real.
Thanks for reading; sorry there are so many questions in one post. Happy listening (and tinkering),
Jamian
