Beolab & Loewe BILD Integration
Folks,
As I mentioned in the "Eclipse" forum, I am very pleased to report that I have finally gotten my BILD7.77 and have very simply and successfully integrated my BL50 speakers. Volume is fully controlled by Loewe remote.
On the devices hooked, Oppo Blueray player 105D and Apple TV 4K have been connected directly in the TV and all the sound management is done by Loewe & Almando Multi Surround in very simple and intuitive fashion.
On the sound front, I have the full control on how the sound is played. I used 2 speaker mode for playing the music and TV speaker becomes silent and when watching Video / Movie, TV speaker becomes the Center Channel. For those who are interested in multi channel surround, Almando box gives you all the connections that you need (Rear / Subwoofer and another set of fronts).
On the screen side, I can switch the screen off when listening to music and the famous curtains are there with all their majesty.
As far as the screen quality goes, in my opinion, it is the best execution of OLED. Very noticeably better than LG C screen (AKA Eclipse :)
On the speaker sound, Loewe have some magic of their own. Sound from the TV speakers (120W) is rich, pristine and very enjoyable and is in complete harmony with my B&O BL 50.
Installing the TV on the stand was as simple as it gets. Typical German precision and mindset.
Design is very Bauhaus... Minimal is maximum. Looks beautiful.
Internet setup was straight forward and Netflix and You Tube etc. have been installed on the Loewe (but honestly they are already there on Apple 4K TV as well).
Internet Radio works like charm. Tidel app comes pre installed. I do not have the service so have not checked out the quality. but no reason to believe it is not the best here either. One can download more apps via the browser and other functionalities.
My next setup goal is using Blue Tooth to stream from Sony WALKMAN.  I also have to learn the full functionality of "ALMANDO Multi Surround) which has so much that I doubt I will fully understand or use it.
I have thrown out my BS5 /MB5 combo. That is piece of garbage now with no ability to connect with Mac and loosing CD ripping and frankly, is not needed any more. Will not need any of the B&O sound products as the Apple TV integration with iTunes and further exploration of Almando already gives me more than I can ever use.
Since I am not a Mutiroom Set up person, I will not be trying that feature of the Loewe / ALMANDO but the Loewe BILD 7 have the full multiroom abilities and in combination with Almando, your imagination and effort is the limit.
Lastly, BILD 7 was imported into the USA from Loewe Gallery in Amsterdam and person in charge there (Cess) is a fantastic source of knowledge and an example of outstanding customer service.
Shipping and custom clearance was a non issue. Simple and straightforward. Delivery was perfect.
I have posted more pictures in the Media section with the music running via Apple TC
Let me know if I can help anyway..
Nice setup! Good to hear and see the brands work nicely together. As soon as my current tv goes out, this is more or less what will replace it.
I do wonder, is that a Loewe subwoofer you have there? I guess this is really not needed when you have a set of BL50's?
Very nice setup, and a no brainer if you want a 77" OLED, that is just great.
I have some small question,
I the Bild 7 with 3D?
Does Loewe have any PUC abilities, or are you using 3 remote controls?
Is there Netflix on the Loewe, I dont no where from, but I got the impression it did not work?
Are you using the Apple tv 4K?
How is the quality of the motorstand, noise  vice?
One more :)
What exactly Almando did you buy, and can you choose speaker type in any kind, or can you do that on the Loewe Bild?
That is not a subwoofer. You are correct. With the BL 50, there is really no need for any subwoofer. That unit you though a subwoofer is actually B&O cart which holds my Oppo and Apple TV.
BILD 7 2017 models are not 3D models. On my 7.77 , it shows 3D as one of the settings but it may just be a carryover from 2016 programming. As I understand, all the LG 2017 panels were without the 3D. Since I do not have any 3D movies, I cannot test if the 7.77 2017 model did indeed have the 3D but I am almost 100% confident that 2017 TVs did not have 3D.
On the PUC abilities, Loewe also have similar capabilities but honestly, I have not tested it yet. One thing I noticed that my Oppo 105 & Apple TV menus were controlled by the Loewe remote too. I will investigate more and report back.
Netflix works fine on Loewe. I have installed the app and used it.
Yes, I am using the Apple TV 4K. Works perfect. I am able to stream music from computer to Apple TV to Loewe and then to speakers.
Motorized stand and speakers are just a class act. Super silent and super smooth. Zero noise. Stands are very high quality material and the speaker bar and the TV back are covered in very classy acoustic fabric.
Loewe has some PUC capabilities. Apple TV can be controled under the STB button. Keep STB + STOP pressed for 5 seconds, than press 27 DONE !
Now Apple Tv can be controled when STB button is active.
Netflix works on the Bild 7
Floorstand is silent
Hi Emil
I bought the following product (Almando Multiplay Surround for Loewe & B&O)
https://almando.com/index.php/loewe-category/loewe-bo/almando-multiplay-surround-powerlink-switch.html
It was amazing how simple it was to connect Loewe BILD & BL 50 with just 2 cables (Cat 7). Almando box had 1 cable in it and I just purchase another Ethernet cable (RJ 45 ends and Cat 7). Nothing else is required. Almando does it all automatically and there is no sound delays.
BL 50 automatically get switched on when Almando detects a sound signal (just like BV TV would do).
Loewe sound set up allows speaker setup and it asks for the range of the external speakers (In HZ) and the distance form your sitting position etc. but of course It does not know if the speakers are BL5 or BL 50 etc. There is no setup required on Almando. There is an app coming from Almando and it may have lots more capabilities to tweak settings but I was informed by their CEO that it will be released very soon once Apple clears it.
Congrats on your purchase, it looks good! Enjoy it
Re 3D questions, all 2016 OLED panels (Generation 1 if you like) across all Bild OLED models are 3D. All 2017 panels are non 3D with 25% brighter colours compared to 2016 panels. Its a tricky one really because me for example, of course I'd like the 25% brighter colours on the later (this year) panels, but equally, I would also lime a 3D cable panel, which is only available from last years 25% less brighter panels! I'll always go with the latest panels at the end of the day and in fact, this is the main reason I've left B&O and looked towards Loewe and other brands. To think I was even going to consider spending c£5k on an older Avant Gen 1 LCD set, what a joke really, compared to what you can get for half the price. B&O are just too far behind. They've lost the edge. All other manufactures have caught up in terms of design, picture and sound capabilities. Nothing makes B&O stand out now. Simon.
