Luke wrote:
Perhaps I have missed it in the user manual but I can't seem to find any information on speaker placement for the Beolab 90's? I was seconds away from purchasing a pair when I thought to double check the space I was going to put them in and found that I would only have 10cm of clearance from the back stone wall and no more than 5cm from the side wall. I can't move them further from the side wall due to the fact the Avant 85" is in the way. The length of the space is 4m across and the side walls come out by about .8m on one side and 1.1m on the other. The room then opens up to 10m x 9m space.
Is this not enough room for the speakers to work effectively? I know they won't look all that fantastic bunched up next to the Avant but i'd love to upgrade from my 5's!
Hi Luke,
the only problem I see with your placement description is the resulting difficulty in accessing the cable connections.
You do not need to worry at all about proximity to boundaries with respect to the audio performance, assuming that you do the Active Room Compensation measurements with the microphone as part of your installation process.
If your Avant is on the wall behind the loudspeakers, then this is also not an issue. If it's on a floor stand and the TV is to the side / nearly in front of the loudspeakers, then there will be some degradation of the BeoLab 90's Beam Width Control (especially the Narrow option) due to reflections off the Avant. I doubt that this will be an audible effect - but it is an effect...
If you have more questions, please feel free to ask!
Cheers
-geoff
