Beolab 90 and Beo remote 1
Nodarkatz13844 wrote:
Razlaw 3,734 Posts OFFLINE Reply Suggest as Answer Verify Answer More Razlaw replied on 07-22-2019 5:45 PM Thank you. That is a different wiring plan than the one I followed. One I followed was same three terminals, also with two grounds on the first terminal, but different colors were indicated. I will rewire and try again.
This is what I found in that link but I cannot understand how did you wired it. Can you please clarify?
The post with the diagram is the one immediately preceding this post of mine.
I can not find the diagram. Can you please post one more time?
Here is the link again for the Beoworld thread. The diagram is in the sixth post in this thread, posted by Esax. I am sorry I do not know how to post just the single post with the diagram.
/forum/general-discussion-and-questions/control-of-beolab-50-using-the-beoremote-1-how-to-pair
I tried bottom diagram and it didn’t work.
Any suggestions?
either the eye is wrong or you have the eye in the wrong socket or something else is going on where you probably need a dealer to come by. incedentally, have you fully updated them to the latest software? Could we maybe get some pictures on how it's all connected? easiest way is probably to use the app for that.
Problem is solved. Wiring was correct.
The problem was that I was not finishing all instructions  on Beoremote 1 . Thanks everyone for your suggestions.
