I want to control Beolab 90 with beo1 remote. IR is connected to master speaker. On remote I have done everything what is required in technical guidance for Beolab 90: setting, advanced, product, Beosound, renamed to Beolab 90. Still no response from Beo 1. Does anyone can help me? Thanks
Beolab 90 and Beo remote 1
I bought the right IR from my dealer.
I followed all his instructions but Beo 1 remote doesn’t control Beolab 90.
Any other suggestions? I read in technical guide for beolab 90 that speakers must be paired with Beosound. How?
The I got from the dealer is the right
I got from the dealer the correct IR. Something I am doing wrong but can not figure it out
I thought about it but never did it . When I am home I will try and let you know. Thank you very much for your help
I tried to unplug and plug back but Beo 1 is still not working with speakers.
