The post with the diagram is the one immediately preceding this post of mine.Razlaw 3,734 Posts OFFLINE Reply Suggest as Answer Verify Answer More Razlaw replied on 07-22-2019 5:45 PM Thank you. That is a different wiring plan than the one I followed. One I followed was same three terminals, also with two grounds on the first terminal, but different colors were indicated. I will rewire and try again. This is what I found in that link but I cannot understand how did you wired it. Can you please clarify?
Beolab 90 and Beo remote 1
I can not find the diagram. Can you please post one more time?
I tried bottom diagram and it didn’t work.
Any suggestions?
either the eye is wrong or you have the eye in the wrong socket or something else is going on where you probably need a dealer to come by. incedentally, have you fully updated them to the latest software? Could we maybe get some pictures on how it's all connected? easiest way is probably to use the app for that.
Problem is solved. Wiring was correct.
The problem was that I was not finishing all instructions on Beoremote 1 . Thanks everyone for your suggestions.
