Beolab 90 and Beo remote 1
Thanks, I give this message to my dealer.
By the chance, do you know correct wiring?
Dealer takes all that money and can't be bothered ensuring the products work. Customer has to use beocare or beoworld. Compare that with other "luxury" brands.
I wired my mine as shown in the diagram in the other thread I posted a link to.By the chance, do you know correct wiring?
And over here anyway my closest dealer is so far away that communications are hampered by delays caused by the speed of light the distance is so great.
Maybe so, but if you pulled your charge card out of your wallet I bet they could smell it from 1000km away.
Do you know how to wire correctly?
There is a wiring diagram posted in that thread. It is in the post by Esax. I wired mine as shown in the lower of the two drawings. Looking at the drawing now again, it does specifically say it is the wiring for the 90s. The date of that post is July 22.Razlaw 3,734 Posts OFFLINE Reply Suggest as Answer Verify Answer More Razlaw replied on 07-22-2019 5:45 PM Thank you. That is a different wiring plan than the one I followed. One I followed was same three terminals, also with two grounds on the first terminal, but different colors were indicated. I will rewire and try again. This is what I found in that link but I cannot understand how did you wired it. Can you please clarify?
