Wondered if anyone had any opinion on the issues I've got with my beolab 9s. I've had them 3 years, being used with a Musical Fidelity A5 preamp and Yamaha streamer. The sound, although occasionally good with some music sounds generally harsh and fatiguing to listen to, I listen to a range of music, mainly electronic on both Tidal and Spotify.
I've tried so far the following to try and improve the sound
: rugs placed on my hardwood floor, change of listening position /room layout, upgrading to high end custom cables to connect the beolabs to the mf5, and finally, a Schitt Audio Loki, which is a high quality tone control.
Nothing appears to fix the issue. I love the style of the speakers and don't particularly want to change them but the sound is just poor, and definitely not a reflection of the price.
Would an upgrade to some beolab 20s offer a decent improvement in the sound? It seems very likely that the preamp would cause an issue, and the yamaha streamer is reviewed as a smooth, warm sounding unit.
I'm reluctant to mess with the potentiometers on the back of the speakers as some have suggested, as assuming it'll just lower a harsh sound rather than fix it?
Any suggestions before I put them up for sale much appreciated
Cheers
