Hello,
I have just bought a pair of older Beolab 8000 Mk. I load speakers, which probably have seen their hay days. At least I don't know much about them, and how they have been used.
I am using them together with a Beosound 3000 and the speakers are connected with a 5m and 8m cable respectively, rolled up as the speakers are only standing less than 1m from the Beosound. Those were the only cables they came with, but they are original B&O cables.
They actually play fine and give a fair sound, but I have noticed this kind of white noise coming from both of them, when the LED is flashing green. It is quite faint, but when you have learned to notice it, you pay attention to it.
As far as I can hear it only comes from the second speaker head counting from the bottom, and it is the same on both speakers. I have also tried to pause the CD and then crank up the volume, but the noise do not increase in magnitude, but stays the same.
I am a novice with these things, so can anybody help me out? Is this normal on the Beolab 8000 Mk.1?
Cheers,
Christian :)
