The previous owner of the condo we just moved into left a pair of Beolabs 8000 installed. I just bought a new samsung frame tv that comes with a one connect box. Is it possible to connect the speakers to this tv?
Beolab 8000 to a Samsung One Connect TV
As long as there is a volume controlled line out, it is easy. Just get a cable and connect to the speakers and set them to line in. If TV does not have a volume controlled line out you’ll need to put a receiver in between the speakers and TV that can be volume controlled.
Is there an adapter for the wires? They both have the 7pin wires?
Sounds like the powerlink input. Look under it, closer to the base. There you find a regular line in socket. Don’t forget to change the switch on the speaker.Is there an adapter for the wires? They both have the 7pin wires?
