There are two defendable reasons for using spikes under a loudspeaker:
- to go through the carpet to the hard substrate to make them more stable
- to reduce the coupling between the loudspeaker cabinet vibration and the floor vibration by making a big difference in the mechanical impedance of the two surfaces
Since this specific question is about the 8000, there is little-to-no mechanical vibration in the baseplate caused by a mechanical coupling to the woofers or a panel vibration caused by internal pressure changes. therefore, the only reason to put spikes under your 8000s would be because of thick carpet on the floor, as has already been pointed out.
If, however, your floor is vibrating when you play bass-heavy music at high levels, then this is probably because the air is pushing/pulling your floor - not because the loudspeaker is causing a mechanical vibration. (I have an identical case in the big listening room in Struer, which is a 26-ton airtight steel box sitting on springs inside a 17-ton airtight steel box. When I play BL90 at high levels, the floor vibrates - but it's because the air in the room is moving it, not because the BL90s are bouncing.)
So, if you have a downstairs neighbour who is complaining about the bass, and you are using BL8000s, spikes will PROBABLY change nothing. You either need to:
- stiffen your floor
- turn down the music
- move
Cheers
-geoff
