I have a blown tweeter i one off my beolab 8000, anyone changed it by there own ? is it possible to replace fairly easy ?
Regards, Christian
Regards, Christian
replacing the tweeter will only be half of the job - different versions of the tweeter have been used over
the last 20 years - recalibrating of the croosover will very likely be necessary
I have replaced both on a pair of 8000 and on a pair of 6000.
Both sounds lovely (as far as I can hear) afterwards. (The 8000 got new and the 6000 got a pair of tweeters from a broken MX7000)
Try do it your self first. If your not satisfied, hand it in to the pro's
B&Ola
Thx for the reply ! I wil give it at go..
Just out of curiosity, does beolab 8000 and 6000 have the same tweeter ?
