Beolab 8000 or Beolab 9 - with B7
I am putting a B&O system in my lounge, and going for the next version B7 (full HD) when it come out.
Now the price for Beolab 8000 + Beolab 2 roughly = a pair of Beolab 9 in Australia store.  I have seen the posts here that says Beolab 9 got enough base already that it doesn't really need a subwoofer.
So what are your recommandations?  should I get Beolab 8000 + Beolab 2 or just go for a pair of Beolab 9?  The speakers will mainly be used for DVD and TV, I don't see myself using it to play music all that much.
Any thoughts?  Thanks :)
By what you said you'll be using them for, i'd reccomend the BL8000's and the BL2, for a beautiful, discreet, with plenty of kick and rumble for movies. But because they cost arond the same as BL9's it is personal preference.
The BL9's are fantastic, but would be more so appreciated when listening to music. Of course if money isn't an issue then BL9's or BL5's would be best!
Go fot the BL 9. More thans enough bass and the BL 9 suits the BL 7-4 much better (you will have 3 acoustic lenses). There are some posts about this subject. What I understood is that the sound changes with the BL 8000 (no acoustic lenses) which doesn't sound natural (especially by watching movies etc..).
 Do a listening test with your dealer and judge with your own ears. I am sure any dealer will allow you to test the set with both options. Remember, your own ears are the beste judge!
Good Luck!
Rob
THe real question is whether to go with the Beo 5 or the Beo 9
Is there a big difference to justify the price difference/
PM
The Beolab 9's will need a sub with the BV7 if you watch movies. For music you do not need the BL2. BL5's are the only speakers that do both jobs without a BL2.
Have you thought of the BL3's and a BL2?
Drop me a PM with your details and I'll add to the list for the 2nd Aussie Beoworld function.
Cheers, Beoaus.
as you say that you will use the speakers for movies, the obvious way to go is BL8000 and BL2, because the BL2 will add more bass to the movies than the BL9 would. The difference between the BL2 and the woofer of BL9 is audible. You will enjoy your movies much more with a BL2.
I had the BeoLab 8000's and a BeoLab 2 when I decided to buy the BeoVision 7, I had to go with the BeoLab 7-2 as the TV was on the table stand.
This setup actually sounds quite good, but if you are to go with the BeoLab 7-4, I would suggest you make the 2 front speakers the BeoLab 9's.
In the future I would like to replace my BeoLab 8000's with the BL9's but I dont know how the mix of Alt/Non Alt front speakers would sound.
JoC
Thanks for the reply :) I would definately ask the dealer to give me a demo, preferably at my place if they can arrange that.
As for Beolab 3, I already have a pair hooked up to my iMac, and for the sake of vanity I want a different set .. lol
Firstly, its what suits you, so best to have a home demo of both setups. I have been fortunate in having tried all the B&O speakers in various configurations.
The lab 2 sub provides an earthmoving effect for movies. I suppose it depends how much bass you want . I find the bl9 offer enough bass for the vast majority unless you like being shaken to the core.
There are two problems I see with the lab 2 and 8000. When i sold my lab 2 I disovered what stereo was again! the lab2 provides an innacurate 'muddy' and slow bass that also ruins imaging so listening to music with bl2 spoils the expereince unless you turn it RIGHT down.
The lab 8000 are using 4in drivers of rather poor quality mated to an amp that is a bit prehistoric now-  the design is almost 18 years old and the only mod in that time has been to improve the circuit to stop the poorly matched drivers burning out! but they sound warm and acceptable but not as good as one would like for the money. They need refreshing- but B&O dont bother as they still sell as they are
I think the 9s provide the best balance, more up do date and other than the BL5 its B&O first serious attempt at a good quality all round speaker without lmitation of poor acoustic material and small drive units.
Itsinteresting that the BL9 are getting very good reviews in almost every sector of the press, difficult to find such priase of the BL8000 unless on this site!!
This is interesting thread:
I have Lab 8000 + Lab 2 setup and I think of conversion to Lab 9.
I use it primarily for listening music. I have not yet listened to Lab 9 but it's good to know that these setups are comparable.
The only concern I have is looks of BL9. I'll be honest looks are very important to me and I can't easily let go of anodized aluminum...
I also like the fact that Lab 8000 are much taller than Lab 9.
