I have tried to read up on Beolab 8000 and the more I read the more confused I get. This is what I think I know for sure:
- Manufactured between 1992 and 2010.
- 1992-1993 3 (2,5) way, after that 2 way
- 1999 upgraded bass elements
- 2003 upgraded circuitry (ABL)
- 2010 replaced by BL 8002. Main technical difference is that ABL is replaced by ICE.
Is this correct? Because I have heard a few people say that the bass upgrade took place 2003!?
But now it starts to get confusing. Some people call the 1999 version Mk2 and the 2003 version Mk3. Other people call the 2003 version Mk2 but don't explain how to differentiate between the pre-1999 and post-1999 versions. In this case there is no Mk3 (although I have heard references to BL 8002 as Beolab 8000 Mk3).
Then there are two crucial s/n circulating, 16992475 which can be found on many sites, e.g., the now defunct link and 10145230 mentioned on . How do these s/n related to the different modifications mentioned above?
I have also seen speaker orginally sold 2006 (I saw the original receipt) with a s/n beginning with 15. Was different versions of the BL8000 sold in parallell several years after the 2003 upgrade?
The original version had some issues with the material in the speaker elements that made them fail prematurely (I have heard at least two explanations - paper that dried or plastic that melted). Which upgrade got rid of this defect?
