Hi all and merry xmas,
I am trying to get my dads BEO System working over the holidays. The amp and system seam to have some issue and therefore I went for the easy option using the BEOLAB 8000 active speakers using the RCA Input and a Google AudioCast. It is working quite well for such an easy solution, except one weird issue:
The BeoLab 8000 should Switch off automatically when no Signal comes trough the cable. This works very well with one Speaker, the other one however is constantly switching off and on again. Once the good- speaker switches off as it should the issue-speaker makes the off sound and the red light goes on, but immediately switches on again (light going green). The issue-speaker then repeatently after one Minute tries to switch off. I have used the exact same setup as on the other speaker, and even swapped all cables around and tried to use them as one alone only. I even tried a patched 5 pin to jack cable which also works fine with then good speaker but not with the other. Both Speakers are set to line in while using RCA line in.
Can anyone help me to find the issue as I cannot use the system with one speaker clicking every Minute when no sound is needed.
Thanks for all your inputs in advance, I appreciate all help!!
Alex
