BeoLab 8000 - Amplifier PCB connector for Line-IN; which pin is what?
For one of my projects I need to connect an external audio source directly to the Line-IN connector on the amplifier PCB. This is a 3-pin connector of which I added a picture to this post. In the picture, it is the left connecter in the row of three.
What I would like to know is what all three pins connect, which is audio left/right, ground and what is the third pin for?
A general handrule is, that the warmest color is right.
I'd say;
Pin 1 Red - right
Pin 2 White - left
Pin 3 Black - ground.
You need all three to transfer a stereo signal.
Thanks for your response Martin.
Does this mean the inegrated amplifier is stereo?
I assumed it was mono to have stereo with two speakers combined.
P4-1 is the audio signal that starts the autostart when you are not using PL cables.
P4-2 is the audio signal that goes to the crossover board
P4-3 is ground
Oh sorry, I forgot the channel selection is done upstream from here.
Pin 1 is for the autostart
Pin 2 is audiosignal
Pin 3 is ground
Thanks a lot!
There are two things I try to understand:
  1. Does "Autostart" mean that the BeoLab 8000 speaker will switch from 'Standby' to 'On' when an audio signal is detected on P4-1?
  2. Is the P4-2 signal the Left or Right channel signal that is being processed to sound one can hear? Also meaning, the P4-1 signal is only for switching, not for hearable sound?
You might notice the auto switching, has a way to aggressive (short) time constant. Watching a movie is pretty much impossible, the BL8000 goes on and off all the time. click, click, click....😁
Thanks all for responding. Happy to have gotten this knowledge from you!
One more thing. Obviously, I am going to use the P4 connector (Pins 1 to 3) for my project. So I will have to order a (3-wire) cable with connector that fits to P4.
Does any one know if this cable has a specific name/type?
(Helps me ordering the right one)
Is the P4 connector a "JST 2.0 3-pin" connector?
