Hello to all.
Does anyone know where I could get the rubber tube that comes with the Beolab 8000 and is used to put the two wires coming out of the speaker.
Thanks.
Hello to all.
Thanks.
thank you
Thank you
These are sometimes called cable socks, or cable tidys.
Not by way of advertisement, but amazing variety if you have never encountered cable sleeves before (e.g. you can even get flexible stainless, copper & brass (<=1/2" dia) to match your B&O anodization instead of just black or white): https://www.wirecare.com/category/braided-sleeving
OK. Thanks
