I recently purchased Beolab 7.1 speaker to use it with my Onkyo tx Nr 807 av receiver as a centre speaker, I managed to solder a trigger cable. It goes from preamp out from the receiver to 7.1, I can hear the sound ok but there’s that annoying static noise. When connected to iPhone with the same trigger cable the static noise is not present. I also connected Beolab 7.4 but same issue. Do you think the trigger cable might has something to do with it? Or should I get the proper cable from sound heavenly? Or is there something wrong with my av receiver? Does anyone of you experienced same problem?
thanks
