Hi everyone,
I have been using my BeoLab 7.1 with a Toshiba TV since 2016 using this lead to connect thought the TVs 3.5mm headphone socket: https://www.av-connection.dk/?PGr=6497
Everything works as it should, power link switched the speaker on and off using the USB in my TV etc. And it sounds amazing when playing music or TV at high volume. But at normal listening volume the dialogue is much too quiet. Especially when there is background music.
Has anyone got this issue as well?
Is the BeoLab 7.1 only 2 channel or is it 3 channel and I have cut out the centre channel using the 3.5mm jack?
Is it because it is designed to work in conjunction with the B&O TV speakers to fill in the dialogue/ centre channel?
I am about to buy a new TV and would like to use this with it through a new Optical lead instead of a 3.5mmw will this help in any way do you think?
