BeoLab 7.1 Bluetooth to LG 2019 TV
Hi, Is anybody running a BeoLab 7.1 as a bluetooth sound bar to an LG 2019 tv? I'm replacing my BV7-32 with a 49" LG, but would love to keep the BeoLab 7.1. All the wired solutions come with compromises, so found a bluetooth kit for the BeoLab. I guess it will work with the TV, but what I don't want is to have to connect the speaker each time.
Take care, Andrew.
Sounds heavenly cable from the headphone jack straight into speaker is the best option.
Why not hdmi arc?
Hi, it's ok i've changed the model of LG tv to one that has a headphone socket. So will go with the SoundsHeavenly option.
Thanks, Andrew.
ARC to a 7.1?
Yes, using something like this, maybe:
Yes, it works great 😀
Thread is called
Beolab 7.2 with hdmi arc
Ah yes. Thanks for the info.
Now just to activate the stands via BRemotes when using LG and all is good!
We have two in our stores just waiting for a solder iron and a tinker!
