Which of the connectors on the BeoLab 6000 PCB, is the audio-IN connector coming from the cinch plug in the foot?
- Is it P003, P004?
- Which wire is Left/Right/Ground?
(Click on picture to see PCB overview)
the Beolab 6000 is a MONO speaker!
With the input selector switch you can select the left or right channel or PHONO offered via Powerlink.
The audio signal arrives on the main board at P3 pin 1, pin2 is Signalground!
the stereo amplifier block is responsible for the bass and treble amplification, for only one channel!
Thnx for responding Wilfried.
So this must be connector P003 on the mainboard PCB?
Yes
