Beolab 6000 stuck in green
Hi all.
One of my Beolab 6000's refuses to return to standby when connected via "line in".
With Powerlink connections all functions well.
I am using them as speakers for a keyboard so they must be wired through the "line in".
It has only just started to do this so I am guessing something has failed and the other one is still working fine.
Does anyone have any ideas?
Many thanks
If you unplug the cables from the two speakers and swap over the speakers, does the fault stay with the same speaker or stay with the same plug on the cable please?  This should help identify if the speaker or the cable is the cause of the issue.
Kind regards, Steve.
Thanks Steve. I did swap the cables over this afternoon with no change but in response your comment I thought I'd swap speakers L for R and R for L leaving the power connectors and leads the same. Now they are both working? Don't ya just love squiggly amps?
No worries, sounds like a loose connection somewhere - glad to hear that all is working now!
