Beolab 6000 strange error .
At powerlink connection:
The speaker is switched on .. the ignition is normal relay klik to green, speker play normal ...when turning off the beosound 3000 than relay in the BL6000 does not turn off and the orange light burns and in the relay is strange noise.
RCA input
The loudspeaker is switched on to green light and works normally, but at the beginning it is a high frequency sound. than play normaly.
If all the audio cables are off.
if I switch between from powerlink to RCA, the RCA turns green and a high frequency comes in from the loudspeaker for a few seconds then it works normally.
If I change the switch position to the PWL, the orange light will flash immediately.
