Beolab 6000 Set Up to Denon Amp
@Lee
You might be right, but I would give it at least a 50% chance that the volume control is before the "link" connection.
Give it a shot 🙂
Thanks for the help everyone. By chance i actually got myself one of these http://soundsheavenly.com/line-in-connection/33--attenuator-.html in the hope it would be one i need. So would it be advisable to get myself a Din to RCA (is that right, RCA?) which will plug the speakers into this attenuator then connect the speaker wire to my speaker inputs on the Denon or is that going to cause mayhem?
This probably sounds silly but the speakers have one line output and din output each. Therefore, do i need to link them with a cable first? It's all very confusing for me, this B&O stuff as lovely as it is sure is complicated unless you have fellow B&O systems to go with it.
I think i'm struggling to find the cables i need too. I just don't seem to be able to grasp this. The powerlink cables, do you have to have something that will plug into both 1&2 then to an RCA. So a duel Powerlink to RCA, one for each speaker?
@choc611
The DIN sockets are Powerlink inputs and require a trigger signal to power on the speakers. In a B&O environment this will happen automatically.
In a NON B&O setup you have to create/provide that trigger signal, and in your case it looks complicated at best!
The Line Input will accept anything you throw at it, and the auto sense will turn on your speakers!
Got it. Thank You VERY MUCH
