Beolab 6000 Set Up to Denon Amp
Hi all,
I have finally got myself a stunning set of black Beolab 6000's for my new house which i can't wait to hook up. I just have to actually move in! Now, what i want to do is create a music station with a couple of my music bit hooked up to run through my new speakers. I have an old Denon amp/fm radio that was part of a 3 tier music system with tape deck and CD deck. I have no use for the two decks so am just utilizing the amp as a controller for my systems.
My main question, i suppose, is what is the best way to connect my speakers to my Denon? I was wondering if i need to connect the two speaker with the 8 Pin Din that has an additional 8 pin. Then into that 8 pin, get a cable like an 8 pin to phono and connect it to my Denon like that?
Or should i use the line connection at the bottom and plug it directly into the amp? in which case, should my amp have two line in ports to connect the two speakers, or will i have to do something similar to above and connect the speakers then run a line off that?
Overall, i want to have my record player running to the amp, playing through the Beo's and maybe an AUX to just plug my phone in. I can connect the record player and an AUX easily, my main question is really the best way to hook up my speakers to my Amp.
Thanks in advanced for any help!
Charlie
You will only be able to plug the Beolab 6000s into the Denon amplifier if it has preamplifier output sockets. You cannot use the speaker outputs as these are at too high a level.
Would be nice to know the exact model....
Check this site:
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
Problem is, i am right in the process or moving house! With no end date confirmed yet which is really frustrating. So for the time being, my stuff is in storage and i can't get over to look at it. What i will do is come the moving date, which i'm hoping with all my heart is next week, i will dig it out straight away and get the model number posted to help.
Thanks for now!
As below...
Thanks for now!
https://www.google.co.uk/search?q=denon+d77&rlz=1C1QJDB_enGB669GB670&espv=2&biw=1600&bih=775&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjBusXNlpvNAhUpCsAKHd5dCqAQ_AUIBygC#imgrc=TEp-T_VD1UYTAM%3A
I have found it!!! Google is amazing. The link will take you to a picture of the rear of the amp and hopefully show you what you're looking for!
From the way the picture looks, you can only connect your BeoLab 6000 using the Line-in RCA on the bottom of the speaker. This will then connect directly to the Speaker Out of your amp/receiver via a SIGNAL ATTENUATOR, which will reduce the Speaker Out level to Line Level.
You can get one from SoundsHeavenly, eBay, Amazon, or make one yourself, like the one I made pictured below.
Good Luck!
I don't think you'll be able to use the BL6000s with that Amp. You need an amplifier with a volume controlled preamp output... You could connect the speakers to the tape out sockets but you won't be able to control the volume and they will be far too loud (loud enough to damage them perhaps?)
The amp does have a processor out loop but again I highly doubt this will be volume controlled....
I believe sounds heavenly sell a speaker out to line level attenuator that will allow you to connect the speaker outputs to the speakers but you will loose some sound quality going that route... Whether the reduction in sound quality will be enough to bother you is a matter of personal taste.
Whatever you do don't connect the BL6000s to the speaker outputs without the attenuator or you will damage them!
Lee
In the meantime, you might want to connect the speakers to an MP3 player first (this will definitely work ok), so you can do a quick audible check on the condition of the drivers.
MP3 3.5mm Line-out > Speaker RCA Line-in
Most BL6000's by this time would have damage to the speaker surrounds, unless they've already been repaired/replaced. Visually, you might be able to see cracks on the rubber surrounds, but you'll definitely hear distortion audibly.
@choc611
If your Denon is the one pictured below,- simply connect your BL6000 to the "processor out" using standard RCA cables....
Move the switch into the Line position,- and enjoy! 🙂
"Made in Germany" Guess that is why its still around 🙂
