Hi all,
I have finally got myself a stunning set of black Beolab 6000's for my new house which i can't wait to hook up. I just have to actually move in! Now, what i want to do is create a music station with a couple of my music bit hooked up to run through my new speakers. I have an old Denon amp/fm radio that was part of a 3 tier music system with tape deck and CD deck. I have no use for the two decks so am just utilizing the amp as a controller for my systems.
My main question, i suppose, is what is the best way to connect my speakers to my Denon? I was wondering if i need to connect the two speaker with the 8 Pin Din that has an additional 8 pin. Then into that 8 pin, get a cable like an 8 pin to phono and connect it to my Denon like that?
Or should i use the line connection at the bottom and plug it directly into the amp? in which case, should my amp have two line in ports to connect the two speakers, or will i have to do something similar to above and connect the speakers then run a line off that?
Overall, i want to have my record player running to the amp, playing through the Beo's and maybe an AUX to just plug my phone in. I can connect the record player and an AUX easily, my main question is really the best way to hook up my speakers to my Amp.
Thanks in advanced for any help!
Charlie
