Beolab 5000 system
any idea where I would be able to see that? The first unit when it arrived had the same problem, but it was in such poor condition I did not give it much thought. This one looks perfect, so hopefully it is something like a loose connection.
Andrew
You are going to need to do some contact tracing with a multimeter. The Beogram 3000 is not that complicated - the service manual is on site. I would however start a new thread as this one is not really relevant and you will get fewer comments. Start another one in the Workbench section entitled Beogram 3000 problem - or similar.
Will the platter rotate by hand ?
Will the motor ?
The belt can sometimes wedge in under the edge of the subplatter.
It looks fine but blocks the platter from rotating.
So all is now in order with the Beogram. All automatic functions are working as they should. It even came with an SP12 cartridge and needle.
I'll be hooking it up this weekend to give all the components a try. I still do not know how to attach the cable tv  to the antenna input.
Regards
Andrew
Today, I hooked up the whole system and was pleasently surprised. The sound quality of the record player was fantastic. To my ears there was no difference to a CD.
Now the bad things.
First of all, accessing the inputs is a struggle as they are under the amplifier??
I needed to wiggle the speaker plug to get sound from the right channel.There was a loud pop whenever I turned the unit on. There was also some crackling when the volume control was moved but this went away as soon as it was in position. I could not test the tuner as I still don't have an antenna connection.
I played a CD through my DVD player (through the TV) but I needed to turn up the volume quite a bit to get the same volume as from the record player.
All in all, I was impresed with the sound from the record player, so I'll contact my local B&O dealer to discuss a complete cleaning of the amp.
Does anyone have any thoughts on why the Cd volume was so low. This is not a problem on my Beosystem 7000, but as I plan to connect an Ipad in the future, i wonder if this will also be a problem.
The Journey continues.
Andrew
Which input are you using? There are level adjustments on the bottom of the Beolab if you need them.
I would imagine that your dealer will have very little idea of what a Beolab 5000 is, let alone being able to service it. Unless you are very fortunate, they will use a centralised service department. Frede is the person to talk about a proper restoration.
I was using the Aux input. Both channels are set to maximum.
I'll discuss with them to see if they can do a general cleaning. If that does not fix it, I'll consider the shipping to Denmark.
Any idea if I can just shove the antenna wires into the socket?
Andrew
As a short term fix, it will do no harm at all. I would try the DVD directly into the Beolab just to see if your TV is reducing the output. Have you been on Frede's site? Well worth it - it has the user manual on and lots of information.
Yes you can - I believe the proper connector is unavailable new anyway, the only source is other people's junk boxes.
Anyway if you have decent off-the-air reception over there, I'd recommend testing with just a loose wire instead of using the cable antenna outlet on the wall. Connecting to the "central antenna" might cause some ground loops and such and bring an unwanted variable in the equation while you are still testing how the kit works. Keep "muting" off so you'll be able to hear the stations even if they aren't strong enough to open the squelch (the level is adjustable, though!).
The Beolab 5000 has a unique design - and users need to know how to calibrate the output levels for the various sources, while also setting the channels right. I take it you don't have the manual?
Here's what you need to do.
Place the amplifier upright, on its left end. Put something underneath it if you want to avoid any scratches to its surface.
This gives you access to the underside. Now, it is quite stable in this position, but do be careful not to topple it.
You need a narrow regular screwdriver.
You'll see that you have a selection of sources available. See the photo below - the various pots are there to help you adjust the output level and balance of each source, and there's a special procedure. Note the TEST button on the front of the Beolab 5000 - you'll need to use that, as we proceed.
As different sources will have different output signal levels, this was how you set them so that each would appear to have a similar level when you went from one to another using the front buttons. Right now, the channel you are using for the CD is set very low, and we need to adjust that.
Here's what you do:
1. Push in the AUX button.
2. Play a mono source through your CD-player. A challenge to find these days, but you're certain to have one.
3. Set the VOLUME slider to 4.5
4. Set the BALANCE all the way to the LEFT.
5. Using the screwdriver, turn both AUX pots all the way down - both L and R - so that the volume is as low as possible.
6. Now turn the L pot up until you like the volume it's playing at (here some would actually compare the level to that output from the record player or tuner, switching between sources. But let's focus on getting a good CD-level now.)
7. Now move BALANCE to the center position - 0
8. Press the TEST button on the front panel, and hold it in - while turning the R pot until the sound becomes as WEAK as possible. (Not kidding you).
9. Let go of the TEST button. You will now hear a perfectly balanced output to both channels, at a level you like.
This was the world's most advanced amplifier when it was launched, and it shows. 😁
