The RG 900 is the first B&O that dad bought. It came with tuner and turntableand was Teak not Rosewood.
He replaced the turntable after a while with a Goldring 75 ( a decision I'll never understand, ugly thing compared to B&O )
Later on he bought the 5000 amp and installed it where the LP rack was on the left hand side. He had a pair of B&O speakers for a while but changed
them fo a pair of AR speakers, also had a couple of B&O reel to reels over the years, but changed to a Sony Cassette deck ( shiny metal and lots of small buttons)
Gas strutts on the radiogram are still fine after all this time and the wood just needs a good clean and sanding, then re oiling.
The tuner powers up but is stuck in one position, I think a cable has snapped. It sounds fine, as long as you like listening to the local radio station in Liverpool?
Unfortunately I don't have room for the radiogram at the moment so it's going into storage, I will take pictures before it gets wrapped up. Also pics of the CDX and BL5000.
I'll also send Frede at Classic Audio the details of the BL 500o's serial number etc
So Far everything has powered up and appears working, I just have no speakers to connect to.
My current system is a Beovision 7 with dvd / cd built in, so one remote and a minimum of cables.
