Beolab 50 on wheels?
The Beolab 50's are quite big as we all know and the best sound quality can be achieved if they have a bit of breathing space on the back. Unfortunately my room is not extremely big and on normal use they are fine just almost against the back wall.
But sometimes I want to go all the way and have them about a meter to the front.
They are extremely heavy and I was wondering if I could place a small set of wheels underneath so I can roll them forward. But what will be the impact on the quality of sound if I have these wheel underneath?
Hi Peter,
I know that Beolab 90 has a moving trolley, which can be purchased from your dealer to allow those speakers to be easily moved as required - I wonder if there is something similar for Beolab 50?
Kind regards, Steve.
Great suggestion, thanks Steve.
I was not aware of their existence and will ask B&O directly. My dealer was already struggling to find the calibration microphone for the 50's ;-)
Peter
A cracking set of results. I would urge anyone to read the “presentation” on the investor website (assuming one is not inclined to read the full accounts).
The transition to a monobrand is explained pretty clearly as are the aims and financial targets of the business.
Difficult to find any negatives although I’m confident sone will try😕
Julian
You should slow down with beers 😁
Not the right thread...
CB wrote:
Julian
Oops. Not had any beer. Maybe that’s the problem.
