Beolab 50 - Lens width adjustment
How do you adjust the width of the lens on the beolab 50s? It doesn't say on the website support page. Is it something that has to be preset during the set-up or can one manually change it according to user preference? Thanks!
https://support.bang-olufsen.com/hc/en-us/article_attachments/115003705074/bang-olufsen-beolab50-whitepaper-v3.pdf
I have seen this document but to make the adjustments you need an app rather than just through the beoremote or setting?
You need to use the App or the remote. I have them and used the app prior to getting a B&O TV. Works great but you need to have them wired together as far as i know to get both of them to change Width.  With WISA you can change the beam with the remote.
I added the Beolab 50 to the Bang & Olufsen app and although it shows me I can select narrow or wide, I can’t change them (connected to Avant NG).
On the Beoremote, from “List”, what do you select to change the width of the beam? Again, don’t seem to see an option I can select to change that.
