Beolab 50 is so unstable with me...
If they work they sound absolutely fab.
but.....
quite often I have one of these two problems (or even both)
1) No wifi connection, so no way of controlling it via the app. where as my home wifi network is stable.
2) No sound/activity at all. They are connected through a high end RCA cable to my Marantz SR8012 receiver.
and it drives me crazy up to the level as being ready to sell them off. Despitethe great sound.
any thoughts, help?
thanks
Peter
Hi peter,
Is there any way you can connect the via wire to the internet? I have had the same issue and the wifi is just bad on these speakers, but for me when i have them wired it’s gone(but then i have an ugly cable theough the livingroom).
On the orher hand, i notice it a lot less as mine are connected to a bv so i don’t have to use the app much.
Your second point iam less sure about, but how do you have your connections setup(in the app/software)? Is the signal set to auto detect? And if so maybe try and set it to rca only.
Also maybe a silly question, but just to rule it out, are you sure it’s not in your reciever? As in, is it sending the signal through?
Michael
Hi Peter
cabel is way to go, I had these problems in the beginning, but after 3 days, I went with cables. My BL50s has run flawlessly since- 3 mouths now.
I am running BeoVision Eclipse 65 wisa to bl50 and bl18, no problem what so ever.
br Peter
I run mine on cabel for 6 months and now on wifi for over 4 months. I hade a dropout once probebly due to my wifi drops out daily. Cabels inbetween and to the 7-55.
Try a LAN over Powerline. Devolo/D-Link etc..
Much better/solid connection than wifi and with the right model you can power-through the Adapter to your BL50 master.
https://www.amazon.co.uk/Devolo-8385-MAGIC-STARTER-2400MBPS/dp/B07H5YPC7D/
Cheaper models available.
I find it just hard to believe that B&O still can't seem to figure out how to do WiFi in this day and age, and on a product as expensive as the BL50! The WIFi on my $500 Auralic Mini works flawlessly, ditto on my $500 Samsung TV.
I think B&O would be better served by never having put WiFi in high end speakers, rather than putting in WiFi that doesn't work. All that does is frustrate owners and lead to public relations problems for B&O. The idea of it is great but only if the execution is also great.
It's rather pathetic isn't it
My BS2 is fine on home wifi, yet my (when I had it) BV14 was shocking.
It was in a room where every other device had zero issues.
The idea that a 30k speaker has similar issues is comical
Thanks all
I will indeed go through the nasty process of adding a network cable through my setup. It needs a few hours of cabling work unfortunstely due to a nasty setup of my living. I am comfortable that the wifi issue will be solved.
As for the  Marantz/no sound issue. I will change RCA outputs to see if that helps.
Otherwise I am still puzzled.
Thanks guys for your support
Much appreciated
Pathetic indeed. Guess it is time for me personally to completely give up on B&O.
As suggested, try powerline adapters if possible. Never failed me, networking my BV11 and Moment to my router.
