I have little to zero knowledge of sound and the related technologies. I am getting the BeoLab 50's and a BeoShape . These will be in a one large space. One end is bar / pub setup and the other end is lounge . Is approx 20 m x 7 m - opens onto patios on either side. That info is so i can get to my questions.
1. can i connect a Samsung tv via optical out to the above speakers. Either all (BEO 50's and Shape) or just to the 50's. Can i also connect other inputs such as blu ray dvd directly and also via the TV?
2. Can i connect directly to speakers via blue tooth - this for easy access for guests .
3. Would an Apple tv connect and make life easier so connect via airplay to speakers - again either all or just 50's or just shape.
4. Will have apple computer with itunes in study - would also like to have that connect to speakers. Is it best to connect on wifi or connect via cables.
5. What is best wireless connection for above - best in terms of ease if use and then sound quality. Will have ethernet and wifi available. As noted also apple TV.
Generally looking for very easy streaming and connectivity options.
