alvinedyvane wrote:
Great stuff Lawrence. I will try this as I did get the Sub working on the previous Beovison 5, it sounded great.
The speakers are self amped though right, so I wonder what the TV takes away or adds?
Is there anywhere on here that shows how best to set up the Beolab 5's with a Beovision 11? Would be good to make sure I have them set up right.
Yes, BeoLab 5s and BeoLab 2 have their own in-built amplifiers. The TV has been programmed at the factory to know that the BL5s produce better bass than the BL2, and so if Bass Management is set to ON in the BV11’s sound settings, it will not send any signal to the BL2.
Honestly, you may as well use it in another setup. I see you have a number of threads on the go here, so perhaps you can find another use for it.
In terms of BL5 setup, there are a number of forum threads that offer advice. I would say:
- Place them where you want in the room. They weigh more than 60kg so you don’t really want to move them around unless you’re really unhappy.
- Connect them to the BV11 with fully-wired Powerlink cables (RJ45 to 8-pin DIN). Steve at Sounds Heavenly could help you with these.
- Tell the BV that the BL5s are connected and define their role, distance from your listening position, etc.
- Calibrate the speakers.
- Pour yourself something cold to celebrate and just enjoy a good movie or album.
Lawrence
