Beolab 5 problem: SPDIF and Powerlink in parallel
I am trying to solve a problem with my Beolab 5. I want to connect my BV 10-46 using Powerlink and connect my Sonos using SPDIF at the same time (to use the Beolab 5s DAC for my Sonos).
So the setup is:
-BV 40 to both Beolab 5s using Powerlink
-Sonos to left BL5 using SPDIF, SPDIF connection from left BL5 to right BL5, sync cable
I tried to set the BL to option 1 and use RADIO to switch on the speakers. Sonos plays on the BL but I dont get the TV signal on it - even if I unplug the Sonos.
I tried option 0, in this case the TV works fine but Sonos does not play on the BL5.
Any ideas what the problem might be?
Thanks for the help!
The problem is that you should use option 0.
HOWEVER. B&O didn't include source data into the BV10!!!
So the BL5's will only "listen" to the spdif input in option 0 when they are in CD source mode.
BV40 won't supply this info onward to the BL5's even if you had a B&O cd player connected via master link.
It's this grandious amounts of fu*kups that makes me sick and tired of the brand.
My old BV5 had source data and it all worked flawlessly.
Great work B&O. 👍
Great work B&O. 👍
Totally agree, there seems to be no consistantcy of approach or forward thinking with regards to the main Audio Video range.
Another example of B&O not thinking things through is with the Playmaker. This ugly, ugly box (great sound though) deserves to be hidden away. However in order to access the line in we have to press A.AUX on the Beo4/5/6., which means if the Playmaker is in a comms room or cabinet this is very inconvenient!
Why oh why oh why,can we not change to line in and adjust volume using an app on the iPhone/smartphone?
This is just lazy development and another reason why the brand is struggling.
Also can we have a Playmaker with a built in amp for BeoVox 2s etc? Playmaker to Pasive kit is again such an ugly solution.
@StUrrock "However in order to access the line in we have to press A.AUX on the Beo4/5/6., which means if the Playmaker is in a comms room or cabinet this is very inconvenient!"
My Playmaker senses the signal of the line-in when I start the source - I can't even control it ("press A.AUX") because it is in Option 0. And it is hidden away too!
I do not see what your problem is.
Greetings Millemis
volume control?
... and what if the line in source is permanentlly on...
some more reasons to come if you wish.
Just give the user the choice. Next thing is you'll be telling us the BeoDound 5 is cutting edge...
GRRRR... ;)
I see no sense in arguing with you, StUrrock
Make your setup as you like - create your own problems.
GRRReetings Millemissen
This attitude resembles B&O brainwashing & arrogance!!!!!
In my case this is a set up a B&O customer wants.
If my customers aren't happy that makes me upset!
I'll make this customer happy and sorry to say this (as is increasingly the case) maybe a non B&O solution.
Re-read this thread a person who seems to love his Lab 5s, appears to be upset from a small piece of neglect from Struer.
This is my point, B&O look after your existing clients and think things through when bringing out new products!
As you and I both know, B&O are only interested in the nouveau-rich.
How's that been working out for you B&O?
Not too good :(
To upset the customers of your flagship audio products, BL5 & BS5 is not a sensible strategy.
On a side note, the majority of our BS5 customers who bought into this product in the early years are now so p*ss*d off that a product that promised so much has had no meaningful upgrades during its life that make it more user friendly and relevant to the modern digital music environment.
Sure they appreciate the sound quality of the BS5, but despite promises made to us dealers at conferences it continues to disappoint.
A case, yet again of so near yet so far.
The BS5 is the modern day LP player the purists love it, quite rightly so.
But to peddle it as a modern music server is rather optimistic at best.
