I am trying to solve a problem with my Beolab 5. I want to connect my BV 10-46 using Powerlink and connect my Sonos using SPDIF at the same time (to use the Beolab 5s DAC for my Sonos).
So the setup is:
-BV 40 to both Beolab 5s using Powerlink
-Sonos to left BL5 using SPDIF, SPDIF connection from left BL5 to right BL5, sync cable
I tried to set the BL to option 1 and use RADIO to switch on the speakers. Sonos plays on the BL but I dont get the TV signal on it - even if I unplug the Sonos.
I tried option 0, in this case the TV works fine but Sonos does not play on the BL5.
Any ideas what the problem might be?
Thanks for the help!
