BeoLab 5 don't work after linkroom setup
I have a BV7 in my bedroom and after configuring it as a Link TV, my BL5s in the living room don't work anymore. All others speakers do... I restarted the BS3 and pull the plugs of the BL5 but nothing happens. Only red lights. Any idea? Thank you
Have you tried unplugging the Masterlink cable from your BeoSystem3? That should show if the problem is related to the link system in anyway.
If the BeoLab5's don't work just off the BeoSystem3 it may be a coincidence that they stopped working when the link was added.
Opman
Maybe your BL5s have an option problem. What are they connected to? Usually - if connected to a Beovision or an audiomaster - they have L.OPT 0.
Hope this helps.
Stefan
Already unplugged Masterlink.
They are connected to the BS3 with a BV4. This is the main room. A BS9000 is also connected as Option 0. In the bedroom I have a BV7...
The other speakers BL3/10 are working, not the BL5. They are not listed in the loudspeakers menu. Calibration works
UPDATE:
Yes it was an Option problem. Thank you!! Didn't know that there's such an option for loudspeakers...
BL5 is the only speaker with link options, because it`s the only one with an integrated IR receiver. So you can use them in a non Beosystem and control them via Beo4/5.
Stefan
These BL5 are little divas...
I had to move them because the floor was oil impregnated. Now I plugged them in and nothing. The LED goes green if I am in the sound menu but no signal noise. Switch back to CD or TV, LEDs are red. Replugged on BS3, L.OPT 0... what else can I do? Thank you
I can't remember the exact symptoms but there was a software issue with beosystem 3 and beolab 5's.  it may be worth having the software updated in the beosystem 3, i think the latest version is 6.11.
Another thought......if you have unplugged the speakers and re-plugged them in to beosystem 3, they will not always take the same position in the speaker allocation menu.  so you might find that if you re-allocate them in the menu and reset their roles, all will be fine.
this is crazy... I connected the BL5 with BV7 in the bedroom and it doesn't work also. BL9 work on the exact same PowerLink connection.
I tried to reallocate but when I'm in the sound setup menu the LED switchs to green but there's  no sound. I could identify which speaker is connected to which port but no sound only from my BL5 though the LEDs say it's on
All worked fine on Thursday. I just plugged them in yesterday and it's quiet. If it's a software bug why did it work two days ago?
