In the interim I have gone and bought a BS9000 from a second-life dealer.
- Congratulations!
Living Room
Beosound 9000
Beolab 5s
Beosystem 3
Beovision 4
Beolab 10
Bedroom
Beovision Avant CRT
I want to ML the BS3 and BV Avant together so that I can watch Sky in the Bedroom.
What I was thinking cable-wise was I'd need:
ML cable to connect the Avant and the BS3 together
- Your BS9000 should also be masterlinked to the system, and connect the BL5s to BS3 - Powerlink front L/R.
SPDIF cable out from the BS 9000 to one of the Lab 5s. Would I then need another one to run between the two Lab 5s?
- Yes.
Powerlink 8/8 x2 so that the speakers know when to turn on.
- These should come from BS3.
Then I'm stuck! How would I connect the speakers to the BS3 so that I can listen to the TV through them?
- Your BL5s are connected to BS3, so you can listen to video- AND audio soureces through BL5s. BS9000 (audiomaster) must be in A.OPT 0 (usually will be set automatically, when no Beolabs connected) - BS3 (videomaster) must be in V.OPT 2. I`d set SPEAKER mode to 1 or 3 for video, and mode 2 for audio, so if you select RADIO, A.AUX or CD BL5s only will turn on. If BL5s detect CD mode, they will switch to digital input. In this case, source selection and volume level control will still work via Powerlink. Set your Avant to V.OPT 6 (link BV). Now you can control all audio´and video sources connected in the mainroom. For video distribution you will need an antenna cable and maybe an RF link amplifier. Your stb in the mainroom must be capable to transmit picture and sound simultaneously via HDMI and SCART (composite). Picture quality in the link room will be standard definition.
Stefan
