Gady wrote:
Hello everyone
Desperately help needed please . I have a pair of Beolab 5 connected to core
via rj45/power link and the second speaker connection is power link to the first.
every time I play music only one speaker works (the first connected via rj45)
however both turn green when I play music
I had tried switching the side and the problem switch side as well
I spent few hr with B&o tech support and they couldn’t help me
if I have the speakers connected to essance I have the same experience
please help any anyone and thank you in advance
There is a known issue with BL5 and BS Core. You need to use Powerlink and Digital cables. I found this out a few years ago when the Core first came out. The Powerlink provides volume regulation and on/off. The digital cables provide the sound.
Login to view imageYou also need to configure the Core.
- Open the Bang & Olufsen app -> Press the cogwheel icon -> Go to "Your products" -> Select your product -> Configure -> Sound -> Optical output -> Disable "Volume regulated output"
- Open the Bang & Olufsen app -> Press the cogwheel icon -> Go to "Your products" -> Select your product -> Configure -> Sound -> Optical output -> Select "48 kHz"
- Open the Bang & Olufsen app -> Press the cogwheel icon -> Go to "Your products" -> Select your product -> Configure -> Sound -> Speaker setup -> Select "Beolab 5"
Note: The Beolab 5 needs to be in option 0 which is the default option.
I hope this helps you and others. Not sure why the Essence doesn’t work? Double check you PL cables as well.
Regards
Stuart
B&O Ealing
