Good morning,
I'm looking for some guidance as to whether or not the Beolab 5's are compatible for use with the Beolab 2. Seems a strange question however my set-up which was working beautifully up until yesterday was an Avant 55 TV with a pair of 8000's as fronts, 4000's as rears and a 2 for the sub. I upgraded to a set of Beolab 5's for the fronts and Beolab 9's for the rears and now the sub will not join in the harmonious party.
I've run through the sound set-up tests and when highlighting the Beolab 2 it does produce the test tone / rumble. For good measure I have also swapped it with another system and it works perfectly in there.
Rightly or wrongly I was told that the beolab 5's will cancel out the need for the Beolab 2 which I hope is not the case. I know the 5's can produce good base in their own right however I don't want to remove the separate subwoofer from my system and have it do what it's designed and built to do.
Is there something I can change in the set-up which will see my Beolab 2 spring back into action?
Regards,
Thomas
