Hi all,
I am contemplating buying a pair of BL5's. Currently I'm using BL9's as my main speakers hooked to a BV10 and masterlinked with a BS3200 and a couple of BL speakers and BL passive amplifiers throughout the house.
What should I watch out for when buying the BL5's? Any SW versions to be avoided or favoured? Will the BL cables used with the BL9's work with the BL5's, too? I currently stream music via a Hifiberry as a V.AUX input to the BV10 - that way streamed music is available on ML and can be listened to from everywhere in the house. I suppose this should work fine with the BL5's, right?
Any tipps, hints or piece of advice highly appreciated.
thanks
Torsten
