Beolab 4000 White
Hi, I am currently having a pair of beolab 4000 in black colour. Looking at the new white colour, I prfer that more now.
Does anyone know how much will it cost in uk to change the aluminum surface of both speakers?
Many Thanks😁
The aluminium surfaces are still silver and just the grills are white.
Are the alumium bodies of yours black? If so there is a guy in the UK who can revert them to silver - he's done work for other beoworld members before with beautiful results.
Chris.
πŸ˜‚Oh.....yes..both the aluminum surface and the grill of mine is black.
So what I need to do is making the aluminum surface in silver, and then order a pair of white grills from dealer? Is that right.....πŸ™‚
By what way I can contact that person, do I need to send those speakers to him?
Many Thanks
justin
Hi Justin,
              the best way would be to send 9Lee a PM (private message) asking him for contact details as he has dealt with him in the past. Hopefully the guy is still actively doing this & the price was very reasonable IIRC.
Yes the replacement white grills should be available from your dealer to complete the renovation - I'd check first though just to be safe.
Chris.
It isn't all that expensive, and you may do it yourself if your practical enough
I replaced one top plate of my 4000 and did it myself, the one plate cost $90 aus dollars. The top and bottom peel off (and are destroyed) the front panels can be easily unscrewed once the grilles are detached.
Hi Dave,
So do you mean that I can just order the top & bottom plate form the dealer?  Since I only manage to get a extra pair of silver aluminum surface for the main body but not the top and bottom plate.
And also, is $90 aus dollars cover both upper and bottom plate, or just a single plate?
Many Thanks
