Hi, I am currently having a pair of beolab 4000 in black colour. Looking at the new white colour, I prfer that more now.
Does anyone know how much will it cost in uk to change the aluminum surface of both speakers?
Many Thanksπ
Many Thanksπ
The aluminium surfaces are still silver and just the grills are white.
Are the alumium bodies of yours black? If so there is a guy in the UK who can revert them to silver - he's done work for other beoworld members before with beautiful results.
Chris.
πOh.....yes..both the aluminum surface and the grill of mine is black.
So what I need to do is making the aluminum surface in silver, and then order a pair of white grills from dealer? Is that right.....π
By what way I can contact that person, do I need to send those speakers to him?
Many Thanks
justin
Hi Justin,
the best way would be to send 9Lee a PM (private message) asking him for contact details as he has dealt with him in the past. Hopefully the guy is still actively doing this & the price was very reasonable IIRC.
Yes the replacement white grills should be available from your dealer to complete the renovation - I'd check first though just to be safe.
Chris.
It isn't all that expensive, and you may do it yourself if your practical enough
I replaced one top plate of my 4000 and did it myself, the one plate cost $90 aus dollars. The top and bottom peel off (and are destroyed) the front panels can be easily unscrewed once the grilles are detached.
Hi Dave,
So do you mean that I can just order the top & bottom plate form the dealer? Since I only manage to get a extra pair of silver aluminum surface for the main body but not the top and bottom plate.
And also, is $90 aus dollars cover both upper and bottom plate, or just a single plate?
Many Thanks
Register to access the forums, reference material, and exclusive member benefits β including our monthly prize draw.
