I'm looking to buy a couple of pairs of these great speakers from flea bay... Can anyone tell me
1) How can you differentiate between those with the black foam inside them that eventually turns to goo, and those with the "stable" white foam, without asking sellers to take their speaker to bits?
2) Did they change the foam when they started production of the Mk2?
3) Did the serial numbers continue in sequence from Mk1 to Mk2?
4) is there a specific serial number point when the foam changed?
Any info will be greatfully received!
Cheers
Nigel
