Hi all, I had a recent problem with my Beolab 4000's, One speaker would power on but with no audio, if I pushed the power button in - out then there was sound for a second or two then it would go off again, So over Christmas I decided to strip the speaker apart. I noticed that the black foam was slightly sticky. After reading up of the dreaded foam rot (inner foam not driver foam) I decided to strip them and remove all the foam.
Upon inspection it seams that the foam may have become conductive and started shorting the speaker. Not sure if the speaker was powering off to protect itself. After removing the foam I checked the boards and all looked good with no signs of corrosion on the contacts. I cleaned all the boards with some contact cleaner and used a very soft toothbrush to remove as much of the foams tacky residue as I could.
I then powered the speakers on with no inner foam and they worked perfect 😁
Does anyone know where I can get some foam to replace the old ??
