Hi Steve,
Thanks a lot for your guidance, this is really helpful.
I live in Berlin and have been looking at what is available on the local version of eBay. There are literally hundreds of subwoofers. I understand what you mean by a sub that has red and white RCA Audio Out sockets fitted. However, it's hard to know exactly what the other qualities of the sub should be. Your cable product linked says 'Suitable for variable level "pre-out" RCA sockets only.'
I can find subs which have output RCA sockets, and also ones that have output sockets that are not RCA but seem to require the wire to be inserted and then screwed shut under a knob (not sure the name of this type of socket). Some subs have both. In some cases, the RCA output specifically says 'low level output' and the screw shut ones say 'high level output'. I assume I want to be sending the high level output to the BL4s, but this means it would be coming from a screw shut knob.
Some other subs are more basic and don't specify so much.
So far I've identified the following, all seem viable. The top one seems the best based on price new and the number of dials on the back of it - in case I need to start adjusting phase and crossover etc. Canton seemed a good brand and it helped narrow the selection a bit.
https://www.ebay-kleinanzeigen.de/s-anzeige/canton-subwoofer-as-85-2/1211317504-172-3404
https://www.ebay-kleinanzeigen.de/s-anzeige/canton-as-200-sc-subwoofer/1209020947-172-3412
https://www.ebay-kleinanzeigen.de/s-anzeige/canton-subwoofer-asd-220-sc-kaum-genutzt/1213024824-172-3480
https://www.ebay-kleinanzeigen.de/s-anzeige/canton-subwoofer-asd-250-sc/1219205257-172-9652
I'd really appreciate your guidance on more specifically what type of sockets I require on the back of the sub. I am willing to pay up to about 200 euros, but I definitely want to get a second hand sub.
I am also definitely up for using Sounds Heavenly to ensure I get the right cables!
I'm pretty technical and enjoy getting involved with detail on this.
Thanks,
Joseph
